roof
  • Thread starter Thread starter alessandra1074
alessandra1074
I have serious problems with a roof of a mountain house.. I just can't get him out in a single "block." in practice I can reconstruct it by doing it in several stages, but obviously these phases fail to intersect and you see two distinct roofs... I hope I've explained... how do I do?
..I also have to insert chimneys and velux, how to do it?
Plus the roof is made of wood and I care to see the beams, how should I do with revit in English?
thank you all,
use the command : merge geometry to "break" roofs.
to make holes on the bonnets, or to remove the roof that does not serve, use the command : vertical openings (from a view of the plant), tracing the perimeter of the roof that must be removed
all the above mentioned commands are present in the group "modification"
Thank you, now I try! :
