rotate multiple blocks at once
  • Thread starter Thread starter zintonio
zintonio
Hello.
There is a command for contemporary rotation of multiple blocks specifying a certain angle. I ask you this x avoid having to repeat the rotation operation for 162 blocks.
I'm going to say:
I forgot the function (default).
the attached file besides wheelblkm (route blocks) also contains scaleblkm (scale blocks).
bye
thank you very much rpor66
I tried and I have to say that they all work very well.
bye bye
Hello. with autocad 2004-2007 and also 2011 you can rotate all the blocks with the property window changing the rotation value. with autocad 2008 I was no longer able to achieve the same result since after rotation (e.g. 90 degrees) the attribute texts overlap one on the other and are no longer legible because instead of turning on the insertion point of the block rotate on the insertion point itself. How come? is a 2008 autocad bag? Is there a variable that restores the rotation of the attribute to the point of insertion of the block? It does not seem serious to me that one should resort to the good will of some lisp programmer (however the mailed lisp works well). Thank you.
