lorenzo83
Hi, I have a problem that I don't know how to solve with catia v5. I have a geometry consisting of non-symmetrical 3d surfaces and I have to rotate it around an axis. what I want to have is the external geometry obtained with rotation. i.e., I'm not only interested in the initial and final geometries, but all the envelope. I have no symmetry axes so I can't get the section and then make a revolution.
to trivialize, you can think of a cylinder built along the x axis that must then be rotated around that y between -10° and +10°. I do not want the initial and/or final cylinder but the "ventor" between the two corners.
Is there a way to achieve this in the casket? At the moment I am trying to recreate the surfaces manually by connecting the base geometry and that rotated with spline...but the result is not at all beautiful.
Thank you for your help.
