rough removal x9
  • Thread starter Thread starter hoytdefiant
hoytdefiant
good morning to all, does anyone tell me how to remove or better still reposition the crude coming from a stl file?
also changing the name to the file of the crude always brings it back to me in the same position.
Masterpieces x9
Sorry I'm late, maybe you've solved the problem, but my doubt was, you can't move it by selecting everything or what you need?
Hi, the crude doesn't let me select it. it makes me import it for the first time but it places it according to the axes in which it was created, so if for some reason I have to move the drawing of the work I find that I no longer have the crude in the correct position and I can not move it.
Maybe you don't have a license for solids, try to check. However, to overcome you could open it with a cad and turn the solid into the position you prefer and then save it in the new position, when you import it you will turn it right, but obviously you will not be able to place it in the position you want on the axes.
