roughing with hole entry
  • Thread starter Thread starter mancino21
mancino21
Good morning, I've just started using powermill 2016 you know how I do in a pocket to always let the cut into a hole previously made
thanks for the help
Excuse me another question... if I have a level with patch surfaces created by me I can only use them on certain processes?? ? because now even if the powermills give them to me anyway and in that area it does not work
hi, for the entry into one or more holes just define the pattern of the entrance points and then select it in roughness on the "enter" page in this case the roughing can automatically create the drilling cycle, indicating the diameter.
sent by my iPhone using tapatalk
for cap surfaces, you manage them as a "until" group instead of "work" in the "default thickness" management if by default you want them ignored in all processing, otherwise if you want to do it inside a specific tool path do the same by clicking the "component thickness" icon that appears on the main page of the processing, next to the "sovrametal" field.
