routing with custom components
  • Thread starter Thread starter McFlurry
McFlurry
Hello.
I would like to use the excellent sw routing tool but unfortunately I met some trouble.
I managed to create a database, using the tables and routing points, of flanges that I would like to use but when for example pitch one of my flanges in the axieme the tool does not recognize the type of pipe to use (I can't choose anything).
if someone knows how to correctly implement the tables with its references can help me! ! !
Thank you very much:finger:
hi mcflurry, I played little with the routing module. Welcome first! the thing that comes to my mind is that it was not defined the "metric" tube model suitable for your one flanges. I believe that there is something explained about the customization of the module.
I recommend reading this post http://www.cad3d.it/forum1/showthread.php?t=13913 and the indication of re_solidworks which indicates that the fields for matching are required.
good routing
Thanks a thousand mechanicsmg... I'm going to kick off the link, but I think I've already visited that post!
I have to do this:
