&rpt.qty does not work
  • Thread starter Thread starter ENZO_ce
ENZO_ce
a greeting to all,
I wanted to ask you two small questions.
I can't understand why creating a table with repetition regions, the parameter &rpt.qty doesn't work, the table doesn't display any quantities, putting other parameters don't give problems;
and then you could tell me what parameter should I insert in the format to display the sheet number?
use wf4
Thank you very much in advance
so on two feet it is not easy to understand.
if you place the files (always that it is possible) maybe we detect the problem.
for the sheet number you must insert
&current_sheet/&total_sheets
will be displayed "1/1" or "1/2" etc.
No parameters needed.
Sorry but to me, ''easy'', she manages to court a girl and not to make the parametric tables:biggrin: :tongue:
to me both.. .
Anyway there is also written in the help, there is no need to see files or anything.
but have you set to table asm.mbr.name?
name is replaced with the parameter indicating the name of the part.
so all parts with that name will be grouped.
the fact is that I have 2 identical tables, one that works (made time ago) and the other that does not work!
the paramentaries are the same but what I create is not going and there is no way!:
