rubber shell for container
  • Thread starter Thread starter pierluigip
pierluigip
Hello, everyone.
they asked me to make a rubber shell (type salvatelecomandi) for a container I made (a set )
Now I've found myself a bit flattered because I don't know what soloworks functionality I have to use, (stampo, .. )
generally I use sheet module , circuitworks and basic functions
I found this:
http://www.cad3d.it/forum1/showthread.php?t=24478&highlight=guscioI looked at the help of the cavity command, but I still couldn't get anything out of it,
How can I at least leave?
p.s. can also attach the axieme file, use swx 2011
I attach files
Maybe I didn't understand what the problem would be.
do you want to understand how to shape your shell or want something more advanced, maybe a solution to have a shell tied to the axieme that changes itself autonomously when changing the size of the metal parts?
for the first solution I would tell you to model the outside, decide the thickness of the shell and empty it, create the various connecting rods.
I hope you've been helped
My advice, since it is something simple, I would make a beautiful extrusion of a rectangle that has as base the shape of the container increased of the thickness of the shell, then a cut (one to insert the contention and the other to access the various buttons) and then the classic fittings of shape. So it's simple, but I don't know if that's what you were asking for.
