I wanted to ask you how I can remove from the model the symbols of roughness that you see in the attached image.
were created in the table.
quoto il buon max!
I use creo modeling and often report this type of "problematic". ..especially when you do the analysis to see if the part is damaged.
there must be a layer that should be called "symbols" or "rugosity"
turn it off in the model and save the state, this will not have any effect in the table.
if the layer does not have to be created and insert roughness.
p.s.: if you create a layer in particular make sure you always call it the same way, in order to avoid that in a large axieme it does not become too long.. .
