rule ilogic extraction idw in pdf&dwg with distinct structure
  • Thread starter Thread starter Donald Haxhiu Work
Donald Haxhiu Work
Good morning. I'm not very good at programming, so I kindly ask here in the forum. I have this ilogic rule found around here in cad3d.it that works perfectly. this rule launched by the general assembly, he goes to detect all parts and subparts and goes to extract all idw drawings in pdf & dwg. But I would have a special need for the company I work for. I would like him to do the same thing at the launch of the rule, so the search for the parts and sub-parties with the extraction of the idw in pdf (dwg doesn't interest me) but that I follow the structured structure of the assembly, so that I go to extract the pdf and put the number of the structure of the assembly that is part of it.
Let me give you an example.
I have this pen in photo n1. and if I go to open his distinct they have this structure in the distinct (photo n2) I if I launch ilogic he clearly goes to take and to do pdf and dwg of all files with the same name. instead I would like to make the extraction of pdf but adding to the file name the number of the structure. then code
0.gr2013100-+-gr.20131.00
1.cr3200800-+-cr32008.00
2.cr3142700-+-cr.31427.00
2.1x5040000600-+-x504.00006.00
3.gr2013000-+-gr.20130.00
3.1cr3198800-+-cr 31988.00
etc.
this would clearly lead to double pdfs you will tell me. I know, but in my company it works so and I feel good that you create pdf doublings of the same file but with the name and location of the structure.
hi, sorry the doubt , but if by chance you have to add to postures an item or for any reason you have to reorder and go to recreate the boards risk to find the same file with different names
I know what the risks are. But let's say they are disposable files. I need it for automatic printing in order as distinct. Then once I do, I'll take it. That's why I don't care. to the worst if I mess gate, and at work finished I relaunch the rule.
