rules for beating handrails
  • Thread starter Thread starter dicifa
dicifa
hello to everyone, I hope I have no wrong place to ask my question....
I have to make a project (industrial plant) where a dancer with handrail is planned....the dancer is raised from land of 800 mm and I wanted to ask if there is a norm that says it is obligatory the beating.. .or know if there is a minimum height where the battepiede itself is not mandatory on the parapet of the scale... is always mandatory the beating?
thank you and excuse me if I have wrong place....
the norm is the uni en iso 14122-3.
if I don't remember the minimum height beyond which you have to put the batter is 500mm.
Monday I ask my colleague who draws the carpenters.
Thank you. . . wait Monday so you can tell me something more precise!
Bye.
Unfortunately, today my colleague is singing.
quoting what was said by gil, it was much more exhaustive, I assumed that the dancer served for access to a machine but could also not be so.
the norm I mentioned to you says that the beating should be put if the dancer is taller than 500mm.
rules are always paid.
I'm a little confused!! !
I practically have to make a cabin with three doors and a ballatoire up to 800mm with 2 stairs...the beating should be put or not?
Well... .
the uni en iso 14122-3 tells you that if you are taller than 500mm you have to put the batter, the one 10809 tells you that you have to always put it.
your dancer is taller than 500mm then applying one or the other the batter you have to put it.
we always put the battepiede (the norm says you have to put it if you see taller than 500mm, and not that you do not have to put it if you are lower).
by curiosity, the fact of putting your beating bothers you for some reason? If I didn't get it wrong, it's a pretty short perimeter or isn't it?
Well... .
Okay, so I have to put it on the stairs?
