s key: how to reassociate it?
graziano-g
hi, following the customization of the keyboard fast commands, the s key pressed in the various contexts no longer makes the link toolbars appear. ...
Can someone give me indication to reassociate the s button then reactivate the functionality?
Hi, I can't find the link bar command. . .
also in the menu customize the last item...
What version do you use?
2022sp5. You may not find it because you are showing only the commands with already an applied keyboard shortcut (voice "show"). try to remove it so you should view all available commands.
hello, you tried to show all the commands from the show menu. in this screen I used solidworks 2023 and the voice is...1709976462997.webpif you continue not to have it then perhaps the best thing is to repair the register or installation of solidworks
hi, repair the installation, no effect.
then so by chance in the tab gestures of the mouse....
