saldature solidworks
ck83
Good morning colleagues, I would have a coriosity to subpoena you.
I've been using solidworks for a week to see if I can set myself up, I come from inventor.
I press that I "get everything back" say, I can work almost quickly as my usual inventor, I have already made table models and customized the basic models of part and together.
All right, in short, if not for the welding function :mad:!
In practice, with inventor they are used to create assemblies of parts to be soldered and then apply welds in the affected areas.
These welds then are perfectly visible in table and rendering as if they were actually solid fittings between the parts.
in solidworks instead I noticed that by inserting a welding cord in the assemblies this is represented virtually or by a "cylindrical cord" that in the table shows all its circular section at the end of the extremities, while in the renderings it is not exactly considered and therefore not represented.
1.webp2.webpsomeone has advice to overcome these "problems"
Thank you in advance! !
in solidworks does not work as in inventor in the management of welded!
in solidworks there is the multibody part in which you manage everything in one file.
weldings weigh down the file, should be put only if necessary.
However, if you don't show the property manager you can't know what settings you put and then what that effect is due to.
Thanks for the answer.
I noticed the difference between inventor and sw in the management of welding but having to learn "in their own" reading guides and watching videos, I still do not know sw well.
I read about the multibody part, but being a completely new thing for me I don't find much in doing the various tests.
I ask vein, but I still don't practice working with multibody files, "I don't know them."
would you know how to tell me a guide or something to deepen knowledge?
there are the integrated tutorials and the program.Immagine.webpadd the version of the program in the profile.
