salome installation problems
  • Thread starter Thread starter cromos
cromos
Hello everyone,
I'm looking to install salome on window 7 64 bit
but during the installation an error screen appears that I attach.
I checked and microsoft visual study 2008 (x64) redistributable is already installed
What do I do to install salome?
Hello everyone,
Actually, it looks like it's blocking during the decompression of the downloaded archive. Did you try to reload it?
I managed to track it down, it should have been caused by an antivirus problem that blocked something.
Now I can throw salomas with run-salome, the screen appears with the home page
but as I click on any icon the program crashes
and to the right of the salome writing 7.3.0 appears the message: He's not answering. )
I have an asus with window7 64 bit card geforce 325m 1giga cuda and 4 giga ram.
I also do not know how to import mesch for example from stl files or other .
exist tutorials for beginners?
I’m studying the first tutorial with creating thewire and it looks like it works.
a thing I would like to know is if salome 7.3.0 is equal to meca salome
or is it another version and should I install it? Where can I do the downlad?
with salome 7.3.0 is it possible to do mechanical stress tests on a mesch?
I am not the same thing: salome-meca has the solutore fem that instead smooth salome does not have.
with simple templates you can only model (you do to say), meshare, and analyze the results of analysis with the post processor. Unfortunately salome-meca exists only for linux, and I do not believe that a version for windows is in anticipation.
So salome is just a mesch modeler. I could use it anyway importing mesch
from blender with stl and then export to step files.
I tried to model with salome but it seems very complicated.
it is better to make mesch in blender and then bring it into salome.
I also have linux
installed on the laptop an asus n61j with window 7 64 bit 4 giga ram and nvdia geforce 325 m
is a configuration suitable for turning meca silhouettes under linux?
I see that there are several versions of meca sausages for linux, what do you recommend?
I downloaded meca salome for ubuntu then I ran the extraction of files and I am trying to load the program I clicked on salomeca-l-gpl.run
the salome-meca mask appears but it freezes and does not fit.
what is the way to properly install mecha salo?
