sandwich
  • Thread starter Thread starter expcic
expcic
Hello.
I am making a simulation on a sandwich panel consisting of vtr skins and cork cores.
I set the layup of the shell181 element that I used to discrete the surface that constitutes the model, I applied the typical loads of the bending on three points. to point out that I have made these mimicles even other times but I have never had any problems.
this time however despite the correctness of the data inserted the deformed of the panel has the typical trend of the case in which the resistance to cut is very low. in practice the deformed is spigolosa.
I just noticed that:
- the difference of modules of young skins and core is high (core 10 mpa and skin 10000)
- at the time when I excessively decrease this difference, or increase to about 1000 the module of the core or decrease to about ten the module of the skins) the defromata loses its spigolocity and assumes a typical form of the case.
Does the 181 shell fail to shape sandwiches with very high module differences between skins and cores?
thanks in advance for any help
I didn't understand the question!
What's your problem? Isn't the deformed correct?
is the result different from the theoretical?
from what I understand you have a sharp deformed when cutting deformation is higher than flexional deformation.
then when the core has a very lower cutting module of the skin module.
If you lower the skin module or raise the core module this does not happen and the deformed is softer.
Everything seems correct. Where's the problem?
wave
Hello.
No, it's normal that the deformed is "spigolosa" as you say. the deformed in the sandwiches is mainly due to the cut because the core, which works in cutting, has little resistance. of course, varying the module of young of the core, various its module of tangential elasticity (because they are linked together with the coefficient of poisson) and, therefore, various the rigidity to cut that in turn varies the deformed.
