k.j.16
In the company where I work in the last period I often use the "restructure" command.
now I have noticed the following:
I have the main axieme to which it contains b which in turn contains c.
I happen to have to bring the c component to the same level of b, that is, under what I perform with "restructure".
but then I want to save by name (and the new set is called d) I can't do it as pro-and tells me that I have to save by name also b because it has external references that point to the latter.
My question is why? ? ?
and above all, can I avoid it? ? ?
