save dxf sheet
  • Thread starter Thread starter Cuspide
Cuspide
to all! I find the difficulty in saving sheets in .dxf . I explain better with a simple example, I have a sheet so made: perforated disc with other 3 holes equidistant angularly between them at a certain distance from the center (the sheet has been generated therefore with only one sketch).
now I have generated with a data table, a set of configurations; but when I try to save in .dxf some of these the operation does not go well.
passing the cursor on the window "dxf/dwg cleaning" that appears to complete the operation, I view the messages
  1. creation of the object failed
  2. impossible to cut some selected elements
I'm wrong with something and if you what? Thank you for your help
Without the file it's hard to see where the error is, you tried to open all configurations and see if someone has any wrong size. . .
Here it is attached. However, I don't think it's a configuration problem because I didn't find it, and then the rescue doesn't happen with any of these.
