save together as part
  • Thread starter Thread starter torok
torok
hello to everyone and good return from vacations for those who have already gone.
I left a theme to the newmacut during the holidays but I haven't had an answer yet.
I have to send a 3d file to my client but I want to send it just as an external encumbrance.
They told me to save the ass as a part. by selecting the option only external faces at that point turn it into igs.
The problem is that sw crascha when I try to save the ass as part.
I tried on different pcs and also with different files but crascha always.
how do you send files to your customers?
save a suggestion is to allege the aid by suspending the internal parts.
or export as part all components and, then delete the components on the tree of the part.
I send them as you said, saving them in part.
Just two days ago though I had your same problem trying to save in part a nice load and went to sw ball closing, I tried several times and eventually I managed, reopening every time sw!
It is likely that it is the size of yours together to give you problems in conversion apart, but if you insist it may be that you decide to do it (only keep the model that interests you, maybe it will do something!)
480083 solidworks crashes on startup on x64 os with internet explorer 8 installed. solidworks
484553 instability in microsoft office applications on some windows vista 64 machines when solidworks is running. solidworks
491900 drawing check-in fails (unable to check in) when installation combination is solidworks 2009 sp 2.0, 2.1, 3.0 and either ms office pro 2002, or 2003 solidworks api
504090 some ordinate dimension arrows are opposing each other (i.e. in wrong direction) for rotated views. solidworks 506573 instability saving assembly as a part solidworks from the assistance they told me that installing the service pack 4.1 should solve the problem.
Effectively cleaning up the layout I managed to save it in part.
But now I have another layout with very few components and if I hide them there's nothing left:frown:
so it does not seem a matter of size mah
now I install 4.1 and tell you
