save together with new name
  • Thread starter Thread starter magicoeste
magicoeste
Hello, everyone.
I have a problem I can't fix.
I have a set pippo.asm composed of pippo01.par, pippo02.par, pippo03.par etc. etc.
I want to create a topolino.asm set composed of mouse01.par, mouse02.par, mouse03.par etc., starting from pippo.asm.
by saving the copy of the axieme, the parts that make up the new axieme are still the old ones. Then I have to replace one for one.
does not exist a faster method? does not exist a safe copy that saves me at the same time both the axieme and the parts that make it?
thanks for the help
Hello, everyone.
thanks for the help
the method is revision manager, from windows on the file name, right click/open with revision manager and from expand the axieme so you see the whole list of components, select them all do the copy operation and then one to one rename the files and finally from the run so you create an identical copy of the starting axieme with all the components with a new name.
what you did, i.e. the save copy by name saved you only the assembling with another name, but the components inside are equal.
