saved in previous versions?
  • Thread starter Thread starter render54
render54
Hello
are a revit user
often here on cad3d new users of revit
ask if you save to previous versions
which does not.
the vs program does it?
mmmmmmmmh,
I would say yes, but I didn't understand why a question like this: what does it have to do with revit?
revit not "retro-save", so we are trying to figure out whether it is a common problem to bim software or whether it is just a autodesk problem.. .
Since when we go to see the presentation of new revit rel this is a recurring question ever and it is said that no because it would be a problem for the basic date of the bim
since allplan saves, archicad saves, vectorwork saves
all programs bim
not that it is just a question of marketing? :confused:
...... I think the question is:
save save, but what bim information does it keep?
maybe with revit you can still "export" for previous versions, but maybe to "save" in previous versions if it means losing information those of revit are more "correct" and they tell you that you can't.
In fact, I think that if objects made with the "longer railing mode" of allplan 2011, I try to bring it to 2008 allplan and the function managed the railing differently, I don't know if it would be able to allow me to change with the same function.
I keep not understanding the problem............ is it to avoid having many licenses updated? otherwise I don't understand why an export to ver.
I believe that it is only evidently one of the problems (or rigidity) of revit nothing but correctness.. ahahaha
an allplan user who speaks of rigidity of revit is like a farmer who gives the villano to a bourgeois! ? you have the software with the steepest learning curve in the industry!
ah... allplan also saves in pdf3d format, and always thanks to god!
you posted in a few hours a dozen messages and didn't have the grace to introduce yourself to other users.
let's follow the rules of the forum.
among these is not to clear phone numbers and email addresses.
Eye.
In reality allplan also saves dwf formats and, wanting vrml (then visible with cosmo player or other freely downloadable applications). I think the pdf 3d is very nice. consider that you can export the whole model with all the textures and view it integrally with the acrobat reader (to understand what we all have on our pcs).
Then I allow myself to break a spear on this "light" of the learning curve of allplan. I think I'm "chats" put around art to counter a software that, always according to my humble opinion, is very valid and powerful. but you know... I'm an allplan user and so I'm definitely on the side.
as regards the initial theme save in previous versions, the answer is Yes. allplan manual source (free of charge from connect portal):
each version saves data up to 3 previous versions. for example 2012 saves in format 2012, 2011, 2009 and 2008. if necessary, as a service, the neme converts your data even in very old versions or vice versa (something tested by my father who started working in 1996 with allplan v10 in unix environment)
come avviene? file -> save by name -> file ndw 20xx (exactly as when you want to pass a word file 2010 *.docx to someone who has a previous version *.doc) or, if multiple files have to be saved at the same time there is a specific tool of conversion (allmenu -> file -> converted in previous versions...).
Why is it important to be able to save in previous versions? simply because often, it happens to me, I have to work with other partners who have unregistered versions.
conclusion: It is essential that software saves data in previous versions. . .
