savings in switching from forged to cast
  • Thread starter Thread starter folle76
folle76
Hello.
the two particular attachments are produced by moulding (not without any difficulty). how much could they come to cost cadauno (including the cost of the equipment) if obtained from fusion? there is no particular need regarding mechanical characteristics. would be 1000 pcs each. Thank you very much. I need a very high estimate.. .
According to me here in the forum nobody is able to give you, or rather, to make you a "preventive".
Have you tried to feel any potential/probable supplier?
Hello.
are particular to be obtained with ease'for microfusion
making a quote is a difficult moment
Because companies are natural for you to pay the mold.
of the particulars
But if you rinse the mold the cost cadauno should be much lower than the details obtained with molding process
when it concerns six tolerances in the order of 0.1 mm for pieces of size up to 25-30 mm
if you ship on the web and look for microfusions you will find a number of specific companies
Thank you very much
Sorry the question, but how come you suggest microfusion and not a normal casting on the ground?
The pieces look like a very simple geometry... .
the attached drawings
7.3 thicknesses
and the type of materials to use
in truth you can use it as fusory technology
also a bunch casting
with shell anime system
but then you have to look for a foundry that merges those specific materials in souls
Thank you very much
