Of course you can.
insert --> dxf/dwg
you can import both with constraints and without and you can select the dwg layers
the studies and skeletons of the machines always amount them in this way.
hi volaff, I agree with colleagues. select a plan, insert the dxf/dwg keeping the constraints, then check a reference quota and finally, select all and stop the sketch.
