scale a component
  • Thread starter Thread starter novizio
novizio
Hello, I receive a valve in stp format and when I open it is 1/10 size compared to the actual.
Is there a command or procedure in inventor to scale it x10??? I read that other programs allow this procedure.:confused:
climb it directly to the import I don't know, but you can derive it in a new part and so you can scale it (bottom left of the junction window the scale factor). then you can stop the connection to the original part and you're fine.
Bye!
Bye!
Thank you as soon as I can try
It happened to me with the .stp.
look in the new file you created with import, if tools-> document->unit settings, is set in mm or in cm.
