scale a set from mm to cm
  • Thread starter Thread starter nicolac
nicolac
I wanted to ask for something I created element, I designed a house in a house with parts giving values in cm,
I drew a table with a set and parts in mm by mistake another day I had nothing to do
I would like to climb the table to get into my hands that you enter the house, so what do I have to do? I went to model scale operations and climbed it by 0.1 I go to measure the values of the quotas and are climbed right, except... then when I bring everything into the house the table is with the same values as before the table as if I hadn't climbed it... I can't climb every part of the table, it's all subjugated.. Help! but I say it couldn't be such a simple thing, how is it so complicated I'm planning? solidwork is a elementary creo toy
It's not complicated.
It is very simple to do what you say... just know!
with a click convert it to cm, km, nautical miles....
If you don't know, it's always hard.
If you know it's always nonsense
Is Chinese difficult? think of the children who speak it only 2 years! for them it is very simple!
Is swx a toy?? It's a toy.
Write in tiny, in a forum to write in uppercase is to scream and there is no need here.
The solution is very easy but, as zimmy rightly said, if you prefer toys .. go to play with those, did not prescribe your doctor to use creo.
The model should not be scaled... because the size is right, there is another thing that is wrong, think about it.
have you tried to contact ptc assistance and ask the question :smile:
Sorry I didn't know, I'll talk low, I thought from 4 to 1:00 in the afternoon but I didn't understand, I'm thinking, thank you for your help! !
You don't have to redesign everything, you have to change the model's measurement units.
I tried, and I had climbed well the measurements, the problem is that if aun together in cm I go insert a set in mm, I don't know why but it puts it back in cm, maybe it's a normal thing, or the settings I have, I went both in model property I tried with the units measuring, and I also tried to climb. It's okay... except when the axieme in which I modified from mm in cm I carry it in that cm...
Perhaps then I did not explain, it is not that I drew the table with cm scale and the house in mm, the house was in mm and the table in mm, only that to say I have a room with quota 920 to say that it was 9 meters , and the table quota is 920 wide, but everything was in mm
It is clear... different units are not allowed in the same together (it would be a delirium the opposite).
Create a set in mm, insert the subaxieme into mm and then convert in centimeters.
