scale and rotation sketch on parallel planes
  • Thread starter Thread starter michaeljack
michaeljack
hello to all
Have patience, I'm learning how to use v5 cat and I'd like to draw a multisection surface that roughly represents the blade of a turbofan.
1. I designed the shovel section
2. I created parallel and equidistant plans
Now I would like to repeat the sketch of the section on the parallel planes, climbing it every time of 3-4% to have a tapered shape and turning it 3-4 degrees.
can you do it without redesigning the sketch every time?
thanks to all
I'm not sure, try like this:
copy the first sketch then dx mouse button paste special with connection
dx mouse button on the sketch just copied and search for the command changes reference of the sketch select the second floor and he will stick them.
then use the commands for the transformations first the ruotes and then with the scale command reduces it
repeat the steps, I hope to have been helpful
