scale director between model and layout windows
  • Thread starter Thread starter mArCo1928
mArCo1928
hi to all, I have recently started using the directors instead of the carryons designed manually with polylinea + text.
I have a problem, I would like to create a director in the model space, which automatically adjusts to the display scale of 2 different windows, one in scale 1:400 and the other in 1:100.
the problem is that the director is equal in both windows, while I would like that in the 1:400 as well as drawn in the model, while in the window set 1:100 it is reduced of its original size of 4 times, or however such that the writing is smaller in proportion to the scale.
I've been clinging to the direction style settings, the director's properties and the scale list, without any result, or rather, the only thing I've managed to get is a bigger director in the 1:100 window, but I want it smaller and it seems there's no way to succeed.
I realize we're talking about the executives' abc, but I never used them before I'm ignorant.
at a time of extreme concentration I finally managed, I returned to the basic setting inside the creation window and modification of the annotative styles. I checked again the "annotative" check and finally figured out what the field was where I had to go to vary the scale of displaying the annotations. or double click inside the display window of the layout and then without selecting anything, in the properties, appears under the submenù "varie", scale annotation.
I went to vary the annotation scale once selected the directors... goat.
