scale view
  • Thread starter Thread starter Marco1960
Marco1960
hello to all, I would like to know if there is, in solid edge, the possibility of showing, in the cartiglio, the value of the scale of the views
Of course, you have to use the call %{scale sheet}
hi be_on_edge, what I would like to appear is the scale of the views, in a 1/1 scale sheet I can put seen with another scale, is this scale I would like to appear. Hi.
depends on how you set the scale of the sheet, in recent templates should be on the first view you put in the sheet.
to change this behavior you can right click on the "set-up tax" sheet surface" (erroneous translation surface of sheet)
as always useful be_on_edge. thanks and hello
It's all right for the new drafts, sometimes, though, I have to change the score by copying
Yes, all right when I make a new draft (if I change the scale after, it correctly updates the value in the cartiglio), but sometimes I just have to change the cartiglio by copying the views from an old, in this case the value of the scale in the cartiglio is not correct (if I draw the relative part with the same scale of the views uploaded is correct, but if I change the scale from the main view copied from the old, the value in the cartiglio does not update). Is there another way? Thanks again and hello.
