Hello everyone, I'm new and I hope you can help me.
I have to make on revit villa mairea of alvar aalto. the main stairs ramp is a nice problem because I can't figure out how to make custom steps. Can someone give me two straights?
Thank you very much
hi, using a component scale, you have the possibility to define in its type properties, construction, type of ramp. The latter is also a system family and in its type properties you can choose which profile to use for the pawn. then operationally, create a new profile family from the metric profile template.rtf, through the parameter button and categories of families, checks as profile usage, scale bald. then load it into the project environment, create a new type of ramp and there you are. for the initial pawn I would say that you are practically obliged to a modeling as a local family.
