schede video
  • Thread starter Thread starter toscaclown
toscaclown
Hello everyone
I have recently assembled a computer with these features:
cabinet midi atx 800w gs
mainboard + ctrl asus p8z77v-lx
fan box
Skeda video geforce gtx 660 2gb
memory ram 2 x 8 gb ddr3
hard disk 250gb ssd + 1 tb
operating system win 7 premium 64 bit
putroppo I still can't work cm I want. . very thick I make mounts with clips that I carry in after effect to add special effects or particular graphics and I would like to see in real time once back in premiere pro (the adobe function link to understand us. . )
My question is: to see the work I'm doing in real time (as long as it's possible.. I have yet to know anyone who works this way..) without having to make it better to have a picture?
. in theory cn a good skeda video should be possible at least to see what I'm doing.. maybe bad, but at least see it in order to make the mounting + feasible. . Now instead, once I get back to the premiere, I see everything at a glance and I can't make precise cuts. . .
I know if I kiedo something feasible or not.. I do complex pictosto stuff ke maybe it's hard to see in real time.. but maybe a different skeda I can improve qlke performance. .
Thank you very much!
to me at work they assembled the new workstation and gave me the usual problem (I have an i7 8core... and a geforce gtx 670). while you are working (or try to launch a render, or a heavy processing) click right on the Windows strum bar and select start task management. geforce should take advantage of the cpu, so in theory you should have very high values. if so you do not have to go to see in the control panel nvidia the settings. ah, look if the nvidia driver was upgraded.. for me was also due to that problem.
If I have well understood in your case it would take a picture....but they cost more than gtx...the difference is in managing the effects in real time and in managing the polygons, you should try 1 before buying it so as to assess whether the expense is worth the gain...(I only have nvidia picture!)
I had 2 gtx but I sold them!!
If you want me to test you with the picture alert!
