scomporre a series
  • Thread starter Thread starter K79
K79
Hello everyone
I have a problem
When I create a series I can't break it, split it, explode it... you see the right term.
I'm not coming or can't? ? ?
go to the browser, open the series and select all that contains --> command " copy " (the one of the family series/copy/ear and not the control c ) --> opens the curtain " copy components " --> turn all yellow balls --> button " below " --> ok
attention that the constraints are maintained only on the generator components of the series, others are in relative but free position to move. Too bad!
this goes for inv. 2012, I did not try on 2014.
always in the browser, expand the series and select the elements, with the dx key you can suppress them or make them independent from the series itself.
I ask again
but as the devil it is possible that on inventor 2012 I create a set with two components, one of them will be used to make the series, and so far everything well..... select the series from the browser schiaccio canc and deletes the series keeping the original element ---> ok.
in the 2013 version if I gate the series also deletes the original element that created the series ----> bug? I don't understand a:::::: settings?? ? ?
I ask again
is an application option setting -> together
