script solidworks
Good morning to all
Could someone tell me how and where to fill out the arguments on the vbs file to pass the arguments?View attachment 68437this example taken from the site codestack | solidworks api, pdm api, c#, vb.net examples and tutorialsbut I don't know how to fill out the file because if I copy and take off exactly what you write there doesn't work
Thank you very much
cation
io ho scritto questa riga di commando
export-sw-models. vbs "z:\sw\351000836" "sldprt" "c:\temp" "step"
and funziona
hello command line poses what do you mean?
I will start the .vbs by double clicking directly on the file
then the scribe must be found in c:\? Can't I start it from the desktop?
if you double-click on the .vbs file nothing happens, indeed you should give a mistake because you do not pass the 4 parameters required
if you write the command line works.
1685647313809.webpbetter still if you write a text file with the .bat extension where you write the command line and then throw it with double click.
hi pose...I entered the parameters in the vbs file, launch it with double click...he opens solid opens the file, but does not create the step...not from any error
Can you say why?
