ing.dir
It will be good to all and apologize if the subject has already been dealt with but I have sought both here and on the net and I have failed to make a clear idea about the matter.
I find myself running on a number of files the same operations, so I looked for a way to automate and optimize everything. Now, in my case I realized that I can solve using the stock recorder and a script to open the folder files in turn and run the created macro.
In general, however, I did not understand what the difference between the various features is. The idea that I did was:
- scripts are the simplest version, it is a list of commands to run in sequence
- the lisp are the most complex tool and to create them you pass through a specific computer language that allows to create more articulated operations
- macros seem to me equivalent to more elaborate scripts, for example, to insert messages in operations. are made from a sequence of actions and can be created or with the voice recorded in the management panel or writing the structure in visual basic
Do you confirm the idea I've done so far?
but above all, help me understand for me understand when using various tools?
