Alex97 Guest Sep 23, 2022 #1 Is there a way in the layout view, inside a window can slide the blocked image vertically or horizontally? Thank you. Attachments Scorrimento diritto.webp 17.3 KB · Views: 2
Legs Guest Sep 23, 2022 #2 the block of the display is born just to avoid this type of modification. the solution is easier than it seems: just unlock it (look in the layout properties) and you can make all the changes you want.
