search for blocks with a given attribute value
  • Thread starter Thread starter zintonio
zintonio
Hello.
I have a design where there is a block with attributes (notes, description, function, acronym, date, etc.). Now the problem is that in the drawing there are blocks that have the known attribute=to others with notes=b others with description=sedia and so on....now if I have to select a block with known attribute=a how do I do?
I don't know if I've been clear... I hope so....
as previously said is only one block with attributes, which then was copied and pasted x all drawing and to each one was modified the attribute.
so if I have to, for example, select or count the symbols that have attributed notes=to I have to do it by hand.
edit/find menu
Write the value to search, activate "list result", click on find, select the found blocks and click on "create selection set".
bye
Thank you very much rpor66,
I didn't think about it at all at the "find". I use the 2008 autocad and works more or less equal and in fact allows me to select and count the blocks with known attribute=a. :finger:
I saw on other discussions a lisp that pulls out a legend of blocks, I wanted to ask if it is possible to do it also for this case that is to block with different attributes?
e.g. table legend
(block 1 note=a ----15 elements)
(block 1 note=b ---- 3 elements)
(block 1 acronym=d34 -- 23 elements)
And so on.
