section along a path
  • Thread starter Thread starter cilly
cilly
Good morning, I would like to extrude a section that follows a path. for example should I draw the round section for a rope that is mounted on two pulleys, after drawing the path with which command can I build the part? in proe it is called sweep this command, I was wondering whether there was also on cocreate or alternatively how to perform this piece.
you must use the rototranslation command in the free geometry menu
Mar
