section screws and dice
  • Thread starter Thread starter fidippide
fidippide
good morning, as a rule of technical design do not dissect the heads of the screws and the dice. unfortunately seize them; How can you do that to keep him from dissecting? Thank you very much.
This is what I wanted to say, but I didn't dare, because then everyone does as they want:) :) :) :)
cmq you have 2 possibilities, or you do it for all views or just for the view you want to update .
for all views go on the 3d property/drafting button do not cut in sections ....... then you have other intuitive options that you can try .
for the view instead you are in the 2d, button dx on the view object ..../property of arrangement .
here you can select either in 2d or 3d and then change by selecting what and clicking on change ... selecting what you would like to do.
it is + difficult to explain that using it....... do some tests and you will understand in flight :)
Dear mcbramby, I think I will use the solution to scourge, in the catpart, uncut drafting > in the sections for all screws and dice. Thank you for your kindness!
Something's not right. I have put the flag in screws and drafting > properties of drafting > not cut in sections but if I do a section me field them equally. if instead I use the command "view in section" then do not dissect them. How come? Thank you!
I usually use "See in section" of the drafting x do sections ........ and it works.
What command do you do in the 2d?? ?
I also use "view in section" usually but I was asked to make a pure "section" this time.
I tried and it's like you say...... I never used that kind of section... .
I don't want it to be done on purpose like this, if you want that type of section, it's x that you want to dissect anything, because if you go into the property of arrangement in 2d the parts have no chance to be dissected
