section together
LucaOt
Good morning to all,
I apologize if the question will be banal but, having recently started using solid edge 2019, I still don't know all possible settings. I often try to dissect together to check the assembly of the pieces in the machine. by default, the software color each piece dissected in blue: Is it possible to change type of display with something more understandable? Thank you.
try using the "section" command you find in the menu' pmi (parlo della st10 che ho nel mio computer, in 2019 may have been moved), you will see the pieces with the colors you assigned to the body of the piece.
come dice @cacciatorino verify that the "coloration" of the details is not only of the faces but also of the body, on the contrary you may find yourself in the condition of having the external faces of your piece of one color but the inside of another.
I think he lowers used the "cutting pipes" function (memory wash, I don't have if under my hand now), which in fact colores everything of blue and no longer understand the boundaries between one piece and the other.
verified live on se2020, in effect with the command "section per floor" in phase of selection of the section plan, color all of a color (which also to me by default is cyan). once the function is finished then, you should find yourself with the fillings of the correct bodies.
