sections 2d (or brochures) in geomagic
  • Thread starter Thread starter pamela
pamela
Hi, I would like to create sections 2d (or prospetti) in geomagic.I already triangolarized the model...if the procedure is long, it is also good only a ladder with the commands I have to use. . .
if you have triangular pattern just create your cutting plans and get the section.
It's not difficult.
if you need to write
hi enrico, then would I ask you how to do it, in geomagic, once you have a triangolarized model to make the edges beveled?
or do you live?
for living edges you have a tool called sharpening wizard, or other techniques to locate the edge. try to find a tutorial on study on the internet, there are several
otherwise write me
the edges are already alive, because after I made the triangolarization the model is all with triangles, the surfaces are not well defined. So I am stuck.how do you make the surface triangolarized a smooth surface? of tutorials I downloaded but until this level do not arrive (or maybe I didn't look good!)...you know how to do it?
do not turn triangles into surfaces... you have to generate them apart.
to do this the procedure is that of reverse engineering and you have to switch to the shape stage.
I mean? through which command can I start this shape phase?
(I have the Italian version)
pamela, now I don't have the program ahead, but in the internal guide to the program there is explained well.
Well then don't answer if you can't, or you don't want to!
I enrolled in the forum to have a concrete help, not to feel a cretin!(I have already tried the guide but you tell me that I have to move to the shape stage seems too generic as what).
I've left messages for two months and I hope someone with good sense and really know how to use geomagic helps me!
Well, since the tone is this and you don't want to read the guide, there's an alternative.
As I think the program uses it for work, you go for a nice course of a week like I did and you pay it fragrantly... always like I did.
an account is to ask how to use a command, another account is to teach you from a to z how the program works.
because geomagic study is precisely for this, to obtain nurb surfaces from scanning data (famous triangles ...).
This isn't the call center of geomagic, so if you don't want to, you can take a nice walk.
to a forum you also subscribe to bring your own contribution ... not only because you need it.
and now let's see if there's someone who really knows how to use it (why am I incapable?) and who teaches it for good.
It is not true that I do not want to read the guide, but it is too generic to say "you have to start the shape stage, read the internal guide"...as if you had not already tried! (even in other messages of 2 or 3 months ago, I don't remember well, you answered me a bit annoyed or "I know everything", but then in concrete you didn't help me, or "given a contribution" as you say!)...I don't think I was the first to start with this tone but from the messenger you sent me you seemed very upset!
I'm not using it for work, but for study!
I didn't ask you to teach me geomagic also because from the cloud of points up to the 3d triangolarized model I arrived alone with my headline and without following any course! !
from to z???? ? I just asked you to tell me where I could start the shape phase!
and then I hope that someone with a little patience can suggest something!not definitely thanks to your help!
I was not annoyed, not having the program in front of me it was difficult to explain by memory the sequence of commands.
by the way, you should also see what version of geomagic you have.
However I repeat that it is a complex operation, because generating the curves that in turn serve to generate the surfaces is just the juice of the problem.
curves are generated almost always manually and their structure depends on the complexity of geometry.
If you want tomorrow morning, at workstations on, I'll give you the controls to access the phase on the surfaces... but then you have to arm yourself with patience because the rest is long to do.
And so I'll leave you caphonically on foot.
"not certainly thanks to my help"I'll put the procedure on you.
of course to do things well and as a rule of art the curves are done in manina and not automatically.
this would require a course of at least 3 days and a few weeks of exercises.
I seriously doubt that another sex would do something like that.
Hey guys,
on do not make the sick.
Did you manage to do what you wanted?
I answer very late but you can get a smooth surface even starting from the triangles that approximate the surface in the tutorial there is a practical example when you are in the triangles phase.
I'll explain better.
if you only need a section it doesn't matter that you move from the shape stage, but you can also model (with many limitations) the triangle phase.
If you need to ask.
hello max, always punctual and useful as always, will we be able to meet sooner or later?
when you pass from Tuscany make you feel
Hello embellishment... is that I am old and so every now and then I leave the ciribiccola.
With pamela we've been blurred, but eventually things have settled.
I'm supposed to happen next month, when the time comes, I'll whistle you.
Don't use my arm too much, or I do?
Hey guys,
If you need to ask.
hi enrico, thank you for the help...it is with max we solved... now I am dimenando con polyworks... we have made the campaign of detection (with laser scanner and total station) but unfortunately not the union! Now I'm trying with the alignment of polyworks.. . ufff
