sections and threads
  • Thread starter Thread starter CRAZYMAD
CRAZYMAD
good day at all I press that is a base of 3 meters for 2 then design on multiple sheets and geometrically complex as it all made on tubular.
you have never happened that if you make a section without change of plan the threads of the cut holes you see
if you create a section with change plan you no longer see
sincerely I am disconcerted in plant you see the threaded hole but in section disappears
in pattern elements never appears thread but in the model is applied correctly
in display cosmetic thread, have you tried to set "quality draft" ?
sometimes dismantling on these parameters reappear.
look if I make a vertical cut I see if I do it horizontally I'm not there if I do it again
I'm losing my mind
