sections of a part in assembly mode
  • Thread starter Thread starter enrico1979
enrico1979
Hello, everyone.
I have to make a mounting manual for a structure (work with wf5).
Now I would like to make an explosion and at the same time a section for those parts with holes for screw housing.
in assembly mode if they dissect the whole structure, I can not exclude elements that pass through the section plan, but that I would like to see in full and not dissected.
For example, by splitting two components, connected by bolt, on the way to the screw axis, the screw is split, and I do not want this to happen.
If they select a single part, from the view manager the section cannot be set as active (unless there is any configuration of the config.pro ).
I can only eliminate the sample of the screw (I have also created two-sided offset sections, in order to bypass the problem in part, but I do not think a program like pro and may not allow such a simple thing that lower level programs allow without any problem).
help me please
