select all entities that make up a block
  • Thread starter Thread starter paolomath
paolomath
Good morning, everyone.
I started playing a little with lisp...
in the hypothesis of wanting to change one of the graphic objects that make up a block (lines, circles, etc.) in a programmatic way, is there someone who can give me some suggestions to select the above objects?
I do not want to use nentsel as it is because it requires me to manually select the object.
For example: to make red all lines that make up a block, how can I select these lines?
with entnext I only see the attributes of the block in practice.
Thank you, every suggestion is accepted. :smile:
Like gp told you, you're gonna swipe with entnext all the subentities of the block.
put a condition that intercepts the lines, a thing of the type (if (= (cdr (assoc '0 entities)) "line") .....)and then choose how to intervene
