select by name or similar
  • Thread starter Thread starter MarcoAtk
MarcoAtk
select by name is possible? I realized that with ctrl-a you select all components of a type (all floors if you leave from a selection of plan, all objects if you select an object at the time of ctrl-a)... but select all that is called "pipe".
In fact, if "pippo" is repeated so many times in many points and in so many subassies it is impossible to find all "pippo".
Are there keyboard shortcuts and a reminder to remind you somewhere?
Mar
you have 2 ways:
1) select a component and use the "selection" tools (all instances of the component). the multiple selection menu is located next to structure and default levels
2) press ctrl+f (find) and search for the component name. with search you find them in succession, with select them all
I have to try now!
mythical! It seemed strange that you couldn't search by name!
Thank you very much
Mar
