select case e if- vba
  • Thread starter Thread starter SimoneCRV
SimoneCRV
Good morning,
someone can explain why the first case doesn't work, but the second one does?
I don't give it out, thank you. o
1stcase
select houses swsubdim.name
houses is = "h_terra": swsubdim.value = userform1.h_terra
end select
2ndcase
if swsubdim.name = "h_terra" then
end if
considering that I have a lot of odds to check, I didn't want you to pass all by if, a select case seemed faster
I did not try, but being two different methods could behave in different ways. in the first case sometimes does not accept that the value (in this case the name of the quota) is calculated by the select case. you could then dimension a string variable first in this way:
dim name_quota as string
name_quota=swsubdim.name
select houses name_quota
end select
test and see if so turns
end select
thank you, but I solved with the classic function "revvia il pc"
Then it all came back to turn as I expected.
