select identical holes in the cat's cam
  • Thread starter Thread starter Dom1900
Dom1900
good evening sorry for the trouble I wanted to ask for information, I did a course for programming with the catia software but I did not succeed a function that allows me to select during a drilling cycle all the holes with the same diameter I thank you in advance to those who will respond
then if you enter the drill you automatically take the holes by selecting the matrix, cmq you just touch a hole and take all the matrix, the important thing that the part is done with casket, because if it amounts a step then it is a problem, I fortunately use the cam inside the company and then on rows made in cascade .. .
I have a part that I don't know how it was drawn
and crushing on deep drilling, as a matrix I find only:
new matrix
copy of current
new from current (shared geometry)
but none of the 3 options allows me to select holes of the same diameter
advanced machinig I don't have it............... but in the surface and prismatic there are holes , if you select a drilling as processing it allows you to select the holes you want to use and if the hole is inside a matrix takes all the matrix automatically ....................
