select internal surfaces
  • Thread starter Thread starter bix
bix
Hi, guys, I'm facing this difficulty:
I created a solid that I have to download. of the last exhaust I must also deform the walls but they are so internal that they cannot be selected with the mouse. is there qlc command that allows you to select internal surfaces and not limit yourself to external ones?
Good morning bix
0) I hope I understand your demands well
1) a possibility is to place you on the area that interests you and then with the keys "cold down" and "cold up " Scroll the entities ... the first are the closest ones then as it goes "back"
2) I don't know which version was made available but from 19 onwards I think you can work with the active section of the solid . It is usually located close to the controls for size, weight, etc.
3) I hope I have not told you about the obvious that you might already know .
Hello expatriate, for me it was not obvious:) very helpful your suggestion!
Are you in the uk? I loved the slag exactly and inburgh to say hello to me if I had to pass. of these times the parks are flourished and lush of young people and carefreeness. Cheers
