selectall, new created objects
  • Thread starter Thread starter mariano.boi
mariano.boi
Hello everyone,
I wrote code to turn a circle into polyline,
to do this, with the command thisdrawing.sendcommand "divide", I created points by selecting circle.
until here everything is fine, but when I have to select points to create polylinea, they are not selected.
place below code:
Code:
private function circle_point() as acadselectionset
        dim setdivss as acadselectionset
        on error resume next
        if not isdbnull(thisdrawing.selectionsets.item("dividess")) then
            setdivss = thisdrawing.selectionsets.item("dividess")
            setdivss.delete()
        end if
        setdivss = thisdrawing.selectionsets.add("dividess")
        setdivss.selectonscreen()
        for each ojarc in setdivss
            ojarc.color = acad_color.acyellow
        next
        return setdivss
    end function
    private sub divide_circle(byval ojarc as acadentity)
        dim div as integer
        dim commandstr as string
         div = thisdrawing.utility.getinteger("numero dividenti: ")
         commandstr = "_divide (handent """ + ojarc.handle + """" + ")" & vbcr & div & vbcr
        if noofpeaces = 1 or noofpeaces = 0 then
        else
                      thisdrawing.sendcommand(commandstr)
        end if
    end sub
    <autodesk.autocad.runtime.commandmethod("arcdiv")> _
     public sub divcirc()
        dim newsset as acadselectionset
        dim filtype(0) as short
        dim fildata(0) as object
        setdivss = circle_point()
        divide_circle(setdivss.item(0))
            if not isdbnull(thisdrawing.selectionsets.item("newselset")) then
                newsset = thisdrawing.selectionsets.item("newselset")
                newsset.delete()
            end if
            newsset = thisdrawing.selectionsets.add("newselset")
            newsset.select(acselect.acselectionsetall,,,filtype,fildata)
            msgbox(newsset.count)
    end sub
    dim commandstr as string</autodesk.autocad.runtime.commandmethod("arcdiv")>
I ask you if you can find some other solution.
of course the command will be shared to the whole forum.
Thank you in advance.
Marian
ps: I am using autocad 2012
I'm sorry, Marian, I can't help you, but I wonder what this command is for? you get something similar with native tools of autocad in less than 5 seconds.. .
