selection for intent
  • Thread starter Thread starter pianta
pianta
on some manuals and in some demos on the net I saw this selection for intent: But unfortunately I can't use it, you know if it has to be activated somehow or if, on the contrary, it can be inhibited (config.pro)?
selections for intent are not managed by config.pro, you must use the right button on the edges or on the faces.
are one of the most important things to know for the correct selection of entities and to give intelligence to our parts and models.
I can think that maybe it's best that you download from the site the quick reference cards, there's everything you need to figure out how to select entities.
the string to be inserted in the config.pro is:
logical_objects yes
(c) this command to be inserted in the config.pro is little known because it seems that ptc has tried to discourage the use of the selection for who knows what reasons. for this must be explicitly enabled.
Bye! ;)
