Atreiou
save to all, or small assemblies that make up triclamp hydraulic fittings
the triclamp fitting is formed by two identical trumpets attached to each other with a clamp and between the two trumpets there is a guranition.
from a few years I work with the axieme that previews the 4 configurations I use
- "full connection" with all 4 components
- "left chord" where a log is suspended
- "denstral arrangement" in which the hanging log is the other
- "I only agree clamp" in which both trunks are suspended and are active only clamp and seal.
everything works perfectly both in combination and in separate base
Now for each of the 4 above-mentioned configurations I have created a derived configuration in which the seal, which is in turn configurable in size and material, varies the material of which it is composed.
the problem that I encounter is that when I insert the component by dragging it from the library opens a window where it makes me choose all 8 possible configurations, if instead I want to change the configuration from the curtain of the context menu of the axieme, I see only the main configurations but not the derivatives
Have you ever happened?
