valeriob
Good morning, everyone. I'd like to know what the procedure is to be done to make a semi-finished raw. I'll explain. we picture a simple piece, a rectangular solid 100mmx100mmx50mm. the starting rough incorporates the finished with an overmetal of 10mm on all the dimensions of the finished i.e. 110x110x60. the finished has a pocket on the upper face and another on the lower one, not passing and not communicating between them. the procedure of execution, I am a cn miller, is to spy first the surface, contornare externally the piece by half height, 25mm, perform a first pocket. You get the first part. so also in the cam that in the path verification environment will go to eat the crude half. when I have to perform the second part, I will need, in cam environment, of course of the finished turned 180° compared to before but I will need to carry behind the semi-finished crude that will have to appear in verification precisely semi-finished so that I can see that the various finishes coincide and that I will not have material that could hinder the fresa in work. how can I keep the raw semifinished in check between first and second part? The example is simple, but I happen to have to cut pieces in several parts, even from semi-finished lathes. or processing in 3d roughed first and finished second and for all these cases and very useful to have an always updated raw semi-finished even to conceive the right attack of the tools in work.
I hope I was clear, thanks to all those who will answer me.
ps. mastercam x5.
ps. mastercam x5.
