separatore decimal
  • Thread starter Thread starter GiLid
GiLid
a greeting to the community.
Is there a possibility to set the decimal separator of autocad from the point to the comma? I installed windows seven on a mac, and the apple keyboard, on the numeric keyboard, has the comma instead of the point. this is particularly uncomfortable as you type a decimal number because you force to move your hand. unfortunately autocad does not adapt to windows settings. Thank you.
international and language options, so cita vista64, seven will be very similar, I guess.
you find it in the control panel, under the voice "personality this system" or something like that.
bye
bye
I thank you for the answer but perhaps I have not been clear in the application display. is not the decimal separotor of window that I want to change (that I changed) but that of autocad.
changing the window separator from point to point, autocad does not adapt by continuing to use its separator.
from here the question. Can you change? (Repeto, that of auocad).
If you mean what you type in the command bar then the answer is no, you cannot change.
